Set of 6 injectors for Renault 25 V6 Turbo 205hp
780,00 €
Six Lucas 6-hole injectors in the Bosch EV1 format, fitted exactly like the originals — the modern replacement for the Renault 25 V6 Turbo 205 hp.
Category:
Description
Would you like to replace the original injectors of your R25 V6 Turbo 205hp with this set of 6 Lucas 6-hole injectors in the Bosch EV1 format (fitted exactly like the originals)?
Besides a flow rate 10% higher than the originals, these injectors are bench-matched (identical flow on each cylinder) and they have the advantage of Rotary Disk technology.
In practice, it is no longer an electric valve sliding inside the injector — an old system that is noisy and whose spray quality deteriorates badly as it clogs up.
In the Lucas injectors, an electric motor sprays the fuel through a disc pierced with 6 holes. There is no longer a sliding valve, clogging is much harder and spray stability is greatly improved.
As a result, atomisation is quieter, the injectors respond faster and, with the higher flow rate, the air/fuel ratio is more efficient.
Treat your R25 to a replacement of its old 30-year-old injectors with these newer, more modern and more efficient injectors.
Replaces Renault reference 7700260543 (77 00 260 543).
