Page 1 sur 1
[VPPRV] Volvo 760, with 3.0 PRV
Publié : 17 févr. 2015, 16:14
par VPPRV
Hello, I'm Ville from Finland. I have a project, my Volvo 760 with B280F (2.8) engine, I have also 3.0 litre ZPJ-engine from Citroen XM, mileage is about 3000km, so it is very impressive condition. Like a NEW!
I will combine them (bottom-end of block and i'll maybe use mechanics valve lifters/rocker arms from B280F)... so that I can get a 3.0 liter engine to my RWD-Volvo. And also later supercharged to it, with Megasquirt EFI and E85 which is high-octane etanol fuel.
-VP
Re: [VPPRV] Volvo 760, with 3.0 PRV
Publié : 17 févr. 2015, 22:18
par SRDturbo
Welcome here
Solid valve rockers is what Renault used wit the Z7X (3.0) turbo.
With E85 knock will not be a problem so you can probably keep the stock pistons if you don't blow too much.
Publié : 18 févr. 2015, 10:26
par VPPRV
SRDturbo a écrit :Welcome here
Yes, thanks. First of the all, I'm thinking keep stock pistons and beams. (First version have slightly 0.3-0.5bar of boost.) Stock component should keep this.. but in future i will need forged pistons and h-beams. Is it some place (France? or somewhere europe) where I would to buy forged pistons to 3.0 PRV-engine? Compression ratio about 9-10. And also H-Beam rods... I will be very thankful...
-VP
Publié : 18 févr. 2015, 12:53
par cooldrick
Welcome on board
Publié : 18 févr. 2015, 22:03
par SRDturbo
CP pistons can make you pistons.
For the connecting rods the ZPJ have the same forged rods as a 200 hp ZPJ4 or a 268 hp Z7X-726 twin turbo so you can probably just go with a good balancing and a shot peening on the stock rods.
